Draw up a schematic of the parts surrounding the IC and post that, it should provide some clues. I usually start by trying to identify the supply pins, ground is typically easy and Vcc is usually not too hard either. Then see if you can figure out what's an input and what's an output, there are a lot of parts that share common pinouts.
