Author Topic: magic smoke escaped?  (Read 1609 times)
Offline firstcolleTopic starter
« on: April 18, 2017, 11:26:04 am »
it's the first time I see a hole in a capacitor... I suppose the magic smoke was escaped.
can you confirm that?
Offline Jeroen_Bezemer
Re: magic smoke escaped?
« Reply #1 on: April 18, 2017, 11:31:39 am »
Usually there is some mechanic deformation involved like bulging out. At least this cap is suspect, as it can/will/already has dried out.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Online wraper
  • Country: lv
« Reply #2 on: April 18, 2017, 11:37:30 am »
That capacitor is certainly faulty. If some rapid failure happens, sometimes gas escapes without capacitor having a time for bulging and only a hole is left. Usually it is either because of rapid overvoltage or AC applied to the capacitor (like rectifier fail). This capacitor looks suspicious though, looks like bended inside a bit, and some punctures around. Might be that it was damaged by external mechanical impact.
« Last Edit: April 18, 2017, 11:39:27 am by wraper »
« Reply #3 on: April 18, 2017, 11:43:55 am »
I exclude some external impact. i'm going to change it and check if it's the only issue in the circuit
