Dear EEV-Forum,... after following Dave for years on YouTube, i finally have a reason to join you. The reason for that is that i cannot found any help elsewere - and i'm sure that there will be some expert out here who can help me out.
A short story to kick things of:
few days ago, I've tried to start my PC (ASRock H87 Pro4 with an Intel Xeon E3-1230V3) from sleep. Since the PC has worked for ages now, and was sleeping for just about 20min, i've expected nothing strange. But then: no graphics, a blinking Power LED (as in sleep mode), and spinning fans. Nothing else happens. So i've pushed and hold the power button to restart the PC. Since then, when i've tried to start it, it just fires the PSU for approx. 1s and even before the CPU fan can start spinning, everthing cuts off. This repeats like every 3s until i kill the power from the PSU.
So i've ordered a new PSU,.. without any succes. Same problem still present. Can't even get to a BEEP or diagnostic LED, neither BIOS.
After doing the generic troubleshooting (CMOS Reset, unplug battery for a while, removing all other Hardware) i've started to get very deep into the hardware and the Mainboard it self. And that is, where my questions start to come up.
I found out, that the MB kills the PSU with the PS_ON Signal wire short after the PWR_GOOD comes up. I've traced the tracks on the MB-PCB to find out, that everything is controlled by a LPC I/O Chip: in this case the Nuvoton NCT6776D
https://media.digikey.com/pdf/Data%20Sheets/Nuvoton%20PDFs/NCT6776F,D.pdf. Studying the datasheet of this IC brings me to a new trace. On page 56 you can find a complete Logic Blockdiagram on how the PS_ON signal is generated. So I continued with probing around the chip signals to get an idea on what signal kills PS_ON output. After just a few hours i found out, that the SLP_S3# Signal was the reason for the cutof of the PSU. As you can see from the blockdiagram, there is a 32ms debouncing circuit between the signal and the AND gate,... and sure enough: when probing the PS_ON# Signal (blue Trace in image) and the SLP_S3# Signal (yellow), there is an exact delay of 32ms.
Obviously the Mainboard somehow sets the PC to Sleep State 3, as soon as the PSU is ramped up all voltages.
Tracing the SLP_S3# Signals over the MB shows, that this signal controls several LDO enables and power FETs of the board power circuitry and is generated by the Mainboards Chipset IC (in my case the DH82H87 S R175).
Now the question: how is this possible? After removing all storage and power from the MB, how can the chipset IC still be stucked in the Sleep mode? Is this even possible without having BIOS or OS running? Is there any expert with knowledge on the processes around a PC boot out there? Is it possible to reset the Chipset IC in anyway? I'm stuck on how to continue this journey here. I'dont think that the Chip is electrically broken, since everything works with controlled and repeatable timing aso.
I've already ordered a new mainboard, and really hope, that this will solve the issue and the CPU is okay.
But i really want to know what is going on here - at least for the purpose of learing, i think you understand!
So, all of my hope is in our your hand!
Thank you in advance,
Regards from Germany
Tony
