Author Topic: SOAR MS-6022 Oscilloscope Repair - Can't find Service Manual (nothing, really)  (Read 1617 times)
Offline fotonTopic starter
  • Country: br
Hi!
First post here.
Bought a Tek 2225 (inspired by Dave's video) and it seems to need repair, because the signals are all convoluted and I can't seem to find the problem.
Today I thought it would be nice to have another oscilloscope to use as a reference.
Then I talked to some people here where I study and soon enough I got a very old and dirty oscilloscope from some very dark room baaaaack there. I also got a tour from the power supply facility, what was awesome! :)
Well, thing is, this oscilloscope is really bad, the signal is all weird and stuff.
Then I took it apart.
Then I remembered: well I could die, better discharge the dischargeable stuff.
But googling the oscilloscope model, I could not find the service manual, even the manual, really, only this ad: http://www.ebay.com/itm/Soar-Corporation-MS-6022-Oscilloscope-MS6022-20-MHZ-117V-240V-/130533750688
Does anybody know a place I could search for the service manual for the oscilloscope?
Thanks!
Attached some pictures of it :)
P.S.: After some minutes on, some white smoke appearde, so I turned it off
  • Country: br
update: googling for some part number on the power supply board I found a pdf and... tadaaa: it seems to be the same (with different model name)
edit: the link, if someone need it:
http://www.magearu.ro/Ftp/Datasheet_3/Multimetre/Hung+Chang+OS-620.pdf
tomorrow I am going to investigate it further
feeling of the moment: will I be able to re assembly it?
