Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Marantz Model 1060 Amplifier transistor equivalent
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Marantz Model 1060 Amplifier transistor equivalent (Read 2608 times)
Rutherberg
Regular Contributor
Country:
on:
April 13, 2018, 03:43:20 pm »
I'm repairing a Marantz 1060 amplifier with a nasty noise on one channel. I isolated the fault, a pair of transistors, 2SC1000 and 2SC493 (H406, H408)
What modern equivalent could I use to replace those ? I attached the schematic.
Thanks
Logged
rsjsouza
Super Contributor
Country:
Eternally curious
Re: Marantz Model 1060 Amplifier transistor equivalent
Reply #1 on:
April 13, 2018, 03:52:28 pm »
If NTE is to be trusted, they claim the following:
2SC1000 -
NTE199
2SC493 -
NTE87
Logged
Vbe - vídeo blog eletrônico
http://videos.vbeletronico.com
Rutherberg
oldway
Super Contributor
Reply #2 on:
April 13, 2018, 08:39:11 pm »
I often use bc547 and bc557 .... Be aware that the sequence of pins is not the same but just do a little acrobatics to place these transistors properly.
At least, with the BC547 and 557, we are sure that it is not about counterfeit transistors and they are easily available in Europe.
EDIT: This is a very common defect on the 70s Marantz.
I advise you to also replace the equivalent transistors of the other channel because there is a strong risk that the transistors of the other channel present the same defect in a short time.
Last Edit: April 13, 2018, 08:46:02 pm by oldway
Logged
Rutherberg
Rutherberg
Regular Contributor
Country:
Reply #3 on:
April 14, 2018, 10:19:41 am »
Thanks for the replies.
I will go for the BC5.. solution on both channels, have it in stock.
Thanks !
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
