Author Topic: MARANTZ SR5600 volume encoder  (Read 3074 times)
Offline firstcolleTopic starter
« on: February 23, 2019, 03:37:43 pm »
I'm looking for a replacement part for the marantz sr5600 volume encoder. i found the service manual and the encoder is an EC16B243040HB but i can't find where i can buy it. someone know if there are some compatible encoder that i can buy?
thanks
Offline pbarton
Re: MARANTZ SR5600 volume encoder
« Reply #1 on: February 23, 2019, 04:29:25 pm »
« Reply #2 on: February 23, 2019, 04:52:26 pm »
Not available.. :(
Offline pbarton
« Reply #3 on: February 23, 2019, 05:23:54 pm »
If you go to https://www.soundservice.gr/e-shop/en/index.php?cPath=22 and enter EC16B243040HB into the search box, then it appears that this same encoder is used in both MARANTZ and TECHNICS products. Have you tried sending email's to MARANTZ and TECHNICS support departments, asking them both...
1. Can they supply a replacement encoder?
2. Failing that, can they recommend a suitable (equivalent) replacement part?
3. Failing that, can they tell you how many pulses per revolution the original rotary encoder provides?
https://north.pl/karta/90msr000240r-potencjometr-sily-glosu-,733-GK-0145.html
Produkt niedostępny = Product unavailable
http://www.alkatreszbolt.hu/szabalyozhato-ellenallas-potenciometer/potenciometer/ls-potenciometer/marantz-90m-sr000240r-rotary-switch-ec16b243040hb.html
Ennél a terméknél kérjük vegye fel velünk a kapcsolatot = Please contact us for this product
eBay item number: 223283908079 looks similar (although it has an extra switch, which you don't need).
Search eBay for "3Pcs/set 6mm D Shaft 18 Position 360 Degree Rotary Encoder w Push Button" the same product is listed 67 times!
Or, if you need 24 pulses per rotation try https://www.reichelt.com/gb/en/alps-stec12e-rotary-pulse-encoder-24-24-vert-w-o-pb-stec12e07-p73922.html?&trstct=pol_8
280 Mechanical Rotary Encoders to choose from here https://uk.rs-online.com/web/c/passive-components/rotary-encoders/mechanical-rotary-encoders/
« Last Edit: February 24, 2019, 08:29:31 am by pbarton »
« Reply #4 on: February 24, 2019, 04:57:11 pm »
I sent an email to marantz asking for a suitable encoder.. I'm waiting for a replay..
Many tanks
Offline pbarton
« Reply #5 on: February 24, 2019, 05:51:24 pm »
While you are awaiting a reply, you could connect your multimeter (in the ohms range) between the centre pin and one of the outer pins on the old rotary encoder. Marantz not powered-up.
Slowly turn the volume knob while observing your meter. Count the number of transitions in one complete revolution. Its probably 24 pulses per rotation, but it could be less? Assuming that the old rotary encoder is still working to some degree?
« Reply #6 on: February 25, 2019, 01:05:48 pm »
Marantz  can't provide me a proper encoder and they can't tell me a suitable part.
my encoder is definitely broken and i cant count the pulse per rotation
Offline mzacharias
« Reply #7 on: February 25, 2019, 02:07:27 pm »
Is the encoder physically broken? They can be opened and serviced if done correctly.
« Reply #8 on: February 25, 2019, 02:10:33 pm »
i've already cleaned it a couple of years ago but now it's completely non responding.
tonight i'm going to take it off and try to clean it again and measure the pulses
« Reply #9 on: February 26, 2019, 02:21:09 pm »
I wrote to alps and they answered me that the family is obsolete and replaced with the EC12E family.
so.. the original part is EC16B243040HB I suppose that the replace EC12E should be EC12E2430404 or EC12E2430401?  24 pulses without dents 20 or 25mm shaft length
Offline pbarton
« Reply #10 on: February 26, 2019, 07:52:40 pm »
Good choice. Order the one with the same shaft length as the original. Well done.
« Reply #11 on: March 01, 2019, 09:19:21 am »
hi all,
based on ALPS advise I ordered these encoders:
EC12E2430804, EC12E2430803, EC12E2460802.
the closest to the original is the EC12E2460802 ut as you can see in the picture the dimensions are completely wrong. in addition the original encoder pinout is A-B-COM and the new one is A-COM-B..
so I did a little wire mod.. not very nice but at least it works now..
