Hey forum folks, here is my latest financial mistake. I picked up this Heathkit condenser checker for a few bucks, it is in poor shape but I have always wanted one, and who knows it may actually be useful!
I know this forum does not deal with tube much, but I hope we won't need any special tube knowledge for this repair. Pictures and a schematic are attached below this post.
The issue is that I cannot get any +150 volts, nothing at all. I actually don't have the right tube for the rectifier, which in this case is a diode connected triode, so in the picture you will see that I put a 1n4007 across the socket instead. I don't know if that could possibly the source of the problem or not. I get loads of negative voltage when I power this thing up, like in the neiborhood of 500V!
I guess what I need is for somebody to explain how this power supply is supposed to work, I have messed with a fair few power supplies but nothing like this one. For reference the tube socket in the chassis is for the rectifier and the socket floating in the air is for a cathode ray "eye" tube.
