Author Topic: + and - power supply short on a board  (Read 2856 times)
Offline jfphpTopic starter
« on: November 01, 2016, 12:01:02 pm »
Hello to all,
I am facing a puzzling problem : on a board full of Fet, op amp (and TTL IC), of course without sockets, I have a short between + and - 15V with no short from either supply to the ground. What do you suggest : a big double power supply delivering several amp and waiting for smoke ? Thank you !
Offline DTJ
Re: + and - power supply short on a board
« Reply #1 on: November 01, 2016, 12:24:10 pm »
Is it a newly built board? One that failed in service?
If its new, go over it with a magnifier / microscope really really well.
Set PSU for constant current of say 200mA, let it run and feel for warm spots. Finger tips first, back of hand, sniff and then use your nose to sense warm spots (only half joking).
With it powered up use DMM on mV range and try to track current path.
Good luck!
Offline CJay
« Reply #2 on: November 01, 2016, 12:34:19 pm »
If the +/- 15V is powering the op-amps why would you expect a short to ground?
Sounds pretty simple to me, you've got a stuffed op-amp or op-amps.
Tracing it, hmm, if the power supply doesn't go into shutdown then as DTJ says, you may well be able to work out which op-amp by the heat but to save your nose from the possibility of an exploding epoxy impact, spray the chips with a little alcohol and see which one(s) dry up fastest.
Offline DTJ
« Reply #3 on: November 01, 2016, 01:07:12 pm »
Spray the chips with a little alcohol and see which one(s) dry up fastest.
That's a great idea. I'll store that one away.
Offline grifftech
    • youtube channel
« Reply #4 on: November 01, 2016, 02:19:13 pm »
fire hazard
Offline CJay
« Reply #5 on: November 01, 2016, 02:31:16 pm »
fire hazard
Potentially, if you're stupid.
However I'd assume that anyone who is capable of using a little critical thought might have the common sense to realise 'a little' wouldn't pour a gallon of alcohol on the board. it just takes enough to 'wet' the top of the chip., not make a puddle.
Offline Monkeh
« Reply #6 on: November 01, 2016, 02:53:41 pm »
fire hazard
IPA evaporates very, very fast, it's not easy to ignite it without a flame.
Online Someone
    • send complaints here
« Reply #7 on: November 01, 2016, 10:17:54 pm »
fire hazard
Plunge a soldering iron into alcohol and watch all the interns start screaming. Autoignition temperature of ethanol: 363 °C (685 °F)
https://en.wikipedia.org/wiki/Autoignition_temperature
Yet its still quite hard to ignite even with the standard metal cartridges which should be well above that temperature. And when alcohol does burn its easy to control and not a great risk.
Offline julian1
« Reply #8 on: November 01, 2016, 10:22:15 pm »
If possible, hook it up to a lab psu, and slowly increase the voltage/current - while trying  identify the source of the heat (indicating the short).
