Author Topic: Marconi 2390 Spectrum Analyser with YIG fault  (Read 810 times)
Offline SparkyBruce
« on: December 13, 2016, 10:33:55 pm »
Hello,
I have just got a Marconi 2390 22Ghz analyser that has a YIG fault with it. It works fine on the lowest "range" up to 2.9Ghz , and it appears to work above that just with a higher noise floor.
Does anyone have a copy of the maintenance manual for this unit. (I have noticed that the ref out signal is not present either - but that might be a different issue).
I do have a paper copy of the standard manual if anyone needs a scan of one.
The unit has the TG option as well as the Quasi Peak option (02 and 08) so it is worth sorting out.
( I also have a HiLO , AR 100HB , and a Holaday HI-6005 to look at over xmas).
Thanks
Bruce
BEng(Hons) CEng MIET (MIEE)
