Author Topic: markings on thermal switches in GE microwave oven  (Read 869 times)
Offline MrWOTopic starter
« on: February 11, 2021, 03:32:14 pm »
I am having difficulty understanding the makings on a thermal switch I removed from a GE microwave oven. The markings on the back NT101 and KIE-on the face:
V 40
70
6320
Offline CaptDon
  • Country: is
Re: markings on thermal switches in GE microwave oven
« Reply #1 on: February 11, 2021, 07:40:10 pm »
Don't know that one specifically. GE used two thermal protectors. One was on the side of the magnetron tube and was a self resetting device, round with two 1/4" spade lugs. The other was on top of the cooking cavity and is NON-RESETTING and most appliance repair parts stores won't sell you one or even sell you an equivalent. It is considered a 'safety' issue assuming if your old one tripped it was from a cooking fire and there may be hidden damage. They are both normally closed and in most cases carry the full load current of the oven so that when they trip the thing goes totally dead!! Don't jump them out, if you get a real thermal issue in the future the oven won't shut down and may cause a kitchen fire. If you can't find a replacement at a parts store check with an 'appliance repair guy' as they may have something pulled from a used oven with a bad maggie or transformer. I may even still have some laying in a box of microwave parts. Some of the non-resetting switches on top of the cavity can be taken apart and reset. There is a 'clicker' bi-metal strip which is meant to hold a tiny microswitch device in the closed position. When the metal strip heats it pops to an inverted arch shape and releases the tiny switch. You can reset the metal strip and re-assemble the switch. You have to bend little metal tabs to take the switch apart.
Offline fzabkar
« Reply #2 on: February 11, 2021, 07:59:17 pm »
Could it be a resettable switch that opens at 70C and closes at 40C?
The following users thanked this post: MrWO
« Reply #3 on: February 12, 2021, 08:50:50 pm »
That was helpful
