Hello everybody.
I'm a newbie in amplificators repair, but hungry to learn.
My (little) experience is more on tube amps but now I'm working on a Marshall valvestate that is an hybrid machine (attached the schematic).
If I attach any cable to the input, also without signal, the amp become very noisy, not a specific frequence (more around 350-500Hz, I've analyzed using an app on the phone), growing when I raise the volume / gain.
I cleaned all, controlled tracks, but no results.
Surely the problem is in the pre-amp part and I concentrated my attention to the TL072 op (IC3 in the schematic) and particulary to the IC3a part.
The power is correct (-12V/+12V to pin 4/8), but with no signal the pins 1/2/3 are all aroung -11.5V, while on the other side pins 5/6/7 are 0V.
I don't know about OP but it seems strange to me, also thinking on how works a tube.
What do you think about? May be an issue of the TL072? To be substituted or before I've to check something other?
Thanks in advance, guys.
