how hot does the chipset get?
no point investigating vcore if its vio that fried chipset
Chipset gets pretty hot: in ~2-3min I can't touch it. I don't let it to become too hot though. Max temperature I let it go was ~70-80 C (measured with pyrometer). I turn on mobo only with heatsink on it.
If vio as far as I understand IO voltage, than I have Video Card and RAM fully working. Shouldn't they have also be damaged if it would be vio?
find chipset power rail, im guessing its getting 5 or 12 v thru shorted regulator
This is a problem, I could find nor this particular motherboard schematics, nor this RG82845PE (SL6H5) northbridge connection principle.
If this regulator(fdb6035al) located above AGP slot on the right side (you can see it on pics above, the regulator has high heatsink): it's drain is connected to 3.3V, source to ground
Why in the world are you even trying to repair that at all?
I usually thow away hardware that's newer.
I have 2 main reasons to repair it:
1) I have the rest of my PCs parts fully functioning (I've tested on another PC).
2) I want to make web server out of this PC.
I agree, but not so much because it is old tech but because Acer stuff is utter garbage.
well, actually it's a bit different brand (AOpen) garbage. While trying to repair it, I studied a lot of ICs connection principles and they (AOpen) cut corners on each circuit:
MOSFET driver (CPU power supply): 2 MOSFETs missing, about 30% of recommended capacitance of Cin/Cout missing, some SMD resistors missing, and I feel like a lot more which I didn't noticed.
RAM power supply: some SMD resistors missing.
And there are a lot of empty slots on the PCB, as you can see on pics I attached earlier.
All this is making me more picky when buying new motherboard.
I attached some pics of northbridge. What do you think, is it looking like burned? I googled something about burned chips, and they say such marks are not a problem.
PS: Thank you guys for answers.
PPS:
Northbridge: RG82845PE (SL6H5)
Southbridge: FW82801DB (SL6DM)
