I am trying to repair a CDI (Capacitor Discharge Igniter) Ignition Unit from a motocycle. I am stuck to diagnose stage since all parts seem to be ok except a PNP SOT23 transistor marked with the code L6 (BSS69 and BSS70) that is connected directly to a power supply monitor MB3773 at pin 2 which is the RESET.
This transistor seems to have short from Base to Collector. I am not sure if under the L6 SMD is a rail that connects BC but I didn't see anything like that until now.
Also, the Base does not seem to be connected somewhere....
So, do you think that this transistor is faulty? Is the connection between Base-to-Collector (shorted) normal?
