Hi!
I'm working with a power supply LRS-100-12. In short it is a 100-230 VAC in 12V 100W out isolated power supply. I discovered by accident (magic smoke involved!) that some of the power supplies measure a resistance between its output GND and the chassis Earth. This value ranges from a few ohms to open (infinite resistance).
As seen in this image taken from the device's datasheet, there is a filter capacitor between GND and Earth. As I understand, this is there to filter out high frequency noise from GND. However the resistance between these pins should measure open, since capacitors present an infinite resistance to DC current/voltage (the voltage injected by multimeter probes in Ohm mode).
Question: is low resistance measured between these pins some anomaly, are some of the PSU's simply defective (or somehow damaged by me), or am I missing something? Thank you!
