Yes, it is probably fixable, but if you are not familiar with electronics as it sounds, I would highly advise you for your own safety to stay away from any repair attempts of switched power supplies! We are talking about voltages of nearly 400V DC here that can still be present for up to several minutes even if the PSU is powered OFF. DANGEROUS!
Apart from that, those things are sometimes not trivial to fix and can be quite stubburn. Usually the switching MOSFET is gone, maybe the IC as well, diodes, resistors can be broken too without you seeing it from just looking at them. If you are lucky it really is only the fuse, but I doubt it. You can check the fuse with an Ohmmeter to see if the resistance is near to ZERO Ohms. If it has a high resistance (Ohmmeter not showing anything) then the fuse is gone and needs to be replaced. You can try putting in a new fuse of the same rating, close the metal case (safety!!) and turn it on - AT YOUR OWN RISK! It will most likely make a big BOOM and smoke starts to come out.
To make this work I would go through a lot of parts with my multimeter and test them one by one, investing at least 1-2 hours of my time before even attemping to turn it on CAREFULLY with some kind of protecting on the mains side (limiting the mains current and voltage). As I do not think that you have enough professional experience with electronics, I would recommend you to buy a new one. You may still sell the broken one on eBay for parts to someone with more experience in electronics.
