Author Topic: Meanwell SE-350-15 Schematic  (Read 3823 times)
Offline German_EETopic starter
« on: August 09, 2014, 04:59:44 pm »
Does anyone have a schematic for the Meanwell SE-350 series? I have one that has poor regulation and I'd like to see a circuit before I start messing around.
Warren Buffett
Offline tautech
Re: Meanwell SE-350-15 Schematic
« Reply #1 on: August 10, 2014, 03:15:57 am »
There are many of these type SMPS PSU's available and Meanwell is only one brand.
I suspect the are all quite similar. Possibly a TL494 controller?
I suggest you identify the SMPS controller IC, get the datasheet and see if any of the typical applications listed match your supply. You may have to get a few datasheets of similar IC's to find what you need.
Offline mij59
« Reply #2 on: August 10, 2014, 03:59:44 am »
How poor is the regulation ?
« Reply #3 on: August 10, 2014, 07:43:41 am »
With no load the output is 14 volts and it is supposed to be a 23 Amp supply
1 Amp load the output is 13,2 volts
2 Amp load the output is 11 volts
3 Amps the supply shuts down.
There is a TL3845 on the primary side and a dual op amp on the secondary side, no other chips. The bridge rectifier and input capacitors are OK and I have checked the output capacitors visually. I sent emails to the Meanwell European Headquarters plus three Meanwell dealers on Thursday but a reply has yet to be received.
Warren Buffett
Offline rob77
  • Country: sk
« Reply #4 on: August 10, 2014, 06:45:28 pm »
then it's definitely not a poor regulation, but a broken power supply ;)
FOUND IT!!!!
« Reply #5 on: August 12, 2014, 06:35:58 pm »
There is an internal shunt and it had a dry joint on one end  :) The supply was trying to regulate past the shunt when under load and failing  :) :) :) :)
Warren Buffett
