Hello, Shakalnokturn.
Thank you for your encouragements.
Yeah, for now, I’m not giving up.
I tried on the AQP to "heat it up" as I already did on Sony consoles. No more result, but I didn’t try to press it. I’ll do the test because visible on the bottom.
What I want to know is where the physical acquisition memory is. On this card, the only ones I saw are 45128163 G5 A75 9JF.
There are 2AQP and 2* 4 memoires on this card. (1 AQP + 4 memoires for channels 1-2 and idem for 3-4)
The question is: Whether these 4 memories, the SNAP processing and the acquisition
or just SNAP treatment?
I ask this question because by changing 2 memories I had a memory error "Snap" because of a bad connection. Now solved.
I can also do a test by isolating a DQ output from the 2 unmet memories to see if the Snap error reappears or not.
I list all the main components on this card, but no other memory a priori if you are interested.
4053BF, AG089LG,C319G,CY2305,152,4558,3771,DS90L,Quick logic 507,74HC04,F02SL,AABD,HEL11,LCX04,Y31S,313,MAX9691,31CC,LCX14,152,151.
There’s some left on the preamp part.
As a reminder, if you put a triangular signal for example, you see the shape of the signal, but it is like "filled", between the shape of the signal and the anointed grond, I think you know what I mean.
Some ideas
cdt
