My first post here, so a friendly wave to you all.
I’m doing some repair work on a high-end condenser microphone. One of the test points I need to measure is the DC bias supply to the capsule, stated on the schematic as normally being 60V +/-1V DC. However, the capsule is extremely high impedance and the requirement for the measuring device is for a minimum impedance of 1Gohm to avoid loading the test point.
DMMs like the HP 3478a and many others have suitably high input impedances, but only on the lower voltage ranges up to 2 or 3V or so. My question is whether there is a meter that offers 1Gohm or more at higher ranges, or whether I need to look at an alternative method of measuring the test point, such as a null meter. Clearly I don’t want to try anything outlandish given the very delicate and very expensive nature of the microphone.
Matt
