Hi everyone,
May I know if there is anyway to measure an ic which is taken from a donor board?
I'm actually technician for iphone and ipad, and there are times i'm taking a chip from my donor board.
So I sometimes when I take the chip works sometimes not! I use diode mode on my multi meter to measure pins.
Does diode measurement work on ics? how can I tell if it's good or bad before putting them on the board?
Thank you.
