Author Topic: Memory module for Fluke 196C  (Read 1738 times)
Offline 1kostik1976
  • Country: ua
« on: February 15, 2017, 05:44:42 am »
Hello everybody.
someone has a memory module for Fluke 196C?
probably in my oscilloscope has broken the memory module ...
Offline Assafl
Re: Memory module for Fluke 196C
« Reply #1 on: February 15, 2017, 02:31:18 pm »
From the service manual:
Item: A201
FLASH/SRAM MODULE 1M x 16 (OLD) Order Number: 4022 246 19431
FLASH/SRAM MODULE 512k x 16 (NEW) Order Number: 4022 246 19841
Nothing at Fluke is simple. The numbers above (AFAIK) can only be ordered by the service department. They'll tell you the number is incorrect.
So you have to tell Fluke it is from the service manual and that they have to find the other part number (the part number).
That is assuming it is available. Also - I am not entirely sure you can buy is since they have to upload the mask ROM and firmware to it.
Offline 1kostik1976
  • Country: ua
« Reply #2 on: February 15, 2017, 04:16:23 pm »
parts 4022 246 19841
Offline ramator
« Reply #3 on: February 27, 2019, 08:40:56 am »
I saw the post about fluke 196. I have a fluke 199c sopemeter with the same type of memory that does not start, I think it may be a problem similar to yours. It can not be up-grade because it does not communicate through the serial port, it may not run the mask software. Please tell me if you have solved this defect and how.Thank you
Offline 1kostik1976
  • Country: ua
« Reply #4 on: March 31, 2019, 06:09:30 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: March 31, 2019, 12:28:24 pm by Simon »
Offline noidea
« Reply #5 on: April 01, 2019, 01:45:13 pm »
I used google translate on the post in Russian before it was deleted and it was still in my history. The translation was:
"I continue to search for a module ... on this module there is poor soldering quality. Try to solder the chips."
Offline lostking2008
« Reply #6 on: August 13, 2020, 01:57:32 pm »
Hi There, I need a memory module for Fluke 199C, but it has been discontinued by Fluke back in 2017. Unfortunately, the service manual doesn't come with the circuit drawing of the Flash/SRAM module (80 contacts in two rows, 0.8mm pitch) itself. Does anyone have a schematic drawing of the memory module?
Thanks,
Ken
