Way late in reply. I hear no clicks after selecting a mode, powering the unit off, pulling and handpiece and then powering it back on, except in simultaneous mode as noted below. If either handpiece is open, there is one click and the 5200 reverts to the left channel, with an OPEN error if the left channel is open.
Test unit is an MX-5200 (factory repaired main board), firmware 1.33. Board isn’t particularly clean from the rework.
I think the matrix is a correct pinout, but I would welcome corrections. I will get a visual trace and photo of the other side of the PCB with the relays out and the goo cleared when I get to replacing one of the relays, and check again. Diagram is looking at the front of the MX-5200 with the face off, which presents the under/back side of the PCB. If you are pinning out while the handpieces with tips are connected, you will get >= 1 ohm on pins where the handpiece has a relation. Without the handpieces everything should be < 1 ohm. My two relays are ~0.22 ohms on left and ~0.05 on right. Pin pair 4,13 in each relay pass through what look like current sense ckts. Pin 11 on the left relay has almost no resistance with pins 4,13 on the right relay but looks like it comes off the feed (well) before the sense ckt.
The power supply in the 5000 and the 5200 appear to be the same layout, and the 5200 main board is a slight respin of the 5000 and an additional sense board glued in. Chassis disassembly is four security Torx 15 in the back and removing the nuts from the F connectors in the front. A 13mm or ½ SAE socket work well for the nut removal. The chassis separates into three sections: blank front, center with main logic/RF board screwed in, and rear with the power supply PCB.
My observation of the relay switching so far is: If only the left or right channel is selected, the left relay is effectively switched out of service to the not-connected pins 8,9. The right relay can switch in either of the channels. In simultaneous mode, the right relay will eventually switch to the right channel, pin 8, and the left relay will connect pins 6,11 which feed pins 6,11 on the right relay, which feed the right channel. While in simultaneous mode, if either handpiece or tip is removed, the left relay switches out to pins 8,9 (n/c) and you are presented with a LOAD ERROR A or LOAD ERROR B message. I need to power cycle the clear the error. If just the left or right channel is selected, then an OPEN error message is displayed and cleared when the error is corrected.
When switching to simultaneous use of left and right, there is one click when the select button is pressed (step 1), about 8 seconds later a second click is heard (step 2), and about 8 seconds later a third click is heard (step 3). The third click is an actuation by both relays.
I cannot switch from right channel to simultaneous if the left handpiece is disconnected. This makes sense. If the right handpiece is disconnected, there is one click and an OPEN error for the right is displayed.
I have noticed some randomness in what channel mode the 5200 selects on powerup after being in simultaneous mode and having used both handpieces. It resumes in left channel mode more than 50% of the time, simultaneous mode a little less then 50%, and on very little occasion, the right channel. If one or both pieces are not used, but remain in the sleeper stands, the 5200 will power up in left channel mode almost all the time on following power-ups. I would think it would come up in the same mode it was last used in if the handpieces are still present. It might be an issue specific to my unit.
