Author Topic: 1991 Nissan Cedric (Japan)  (Read 2639 times)
Offline Jeff eelcrTopic starter
Re: 1991 Nissan Cedric (Japan)
« Reply #25 on: March 16, 2023, 12:44:23 am »
Pictures added to 1st post
1-3 Monitor
4 back of front panel
5 CD front
6 CD rear
Jeff
Offline cantata.tech
« Reply #26 on: March 16, 2023, 02:06:53 am »
As I originally thought, it's a Matsushita (Panasonic).
The good news is that they continued to make them and the cables are available for later models. A bit of work with some tools can probably get a fit, if not I use a 3D printer to make up custom long-lost connectors.
There will be manuals for later models that will be similar enough to enable you to get it to work (maybe/to-a-degree).
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #27 on: March 16, 2023, 04:05:42 am »
Those connectors look like standard stuff. I can buy them locally online for a couple dollars each.
Offline austfox
« Reply #28 on: March 16, 2023, 06:44:48 am »
Nice car. To see the AV system (with touchscreen) forward to around the 9:15 mark:
https://youtu.be/dg4Vfw24Z_Q
