Author Topic: Metcal MX500P [SOLVED]  (Read 2054 times)
Offline Free_WiFi
  • https://tinyurl.com/y5nhpt2x
« on: July 26, 2017, 12:05:33 pm »
I own the Metcal MX500P power supply.
The model that i own is the 1 without the display :
My trouble is: when im using the power supply with the hadler (MX-H1-AV) my hadler after some minutes is going to get hotter in the middle of the hadling zone.
So im thinking to open my power supply and replace all capacitors,maybe this could fix my problem or maybe the problem is the hadler it's self ?
« Last Edit: August 03, 2017, 11:49:01 am by Free_WiFi »
Offline Armadillo
Re: Metcal MX500P trouble
« Reply #1 on: July 26, 2017, 12:32:31 pm »
Go to home depot get yourself the armaflex pipe insulation sleeve then sleeve a portion onto your soldering pencil and you won't feel the heat.  ;D
Offline MosherIV
« Reply #2 on: July 26, 2017, 12:48:40 pm »
Sounds like the inductor in the handle is overheating. They are available as a replacement part.
Offline Free_WiFi
« Reply #3 on: July 26, 2017, 01:10:31 pm »
Do you mean this one ?
P.S this pic is not of my handler ,ive taken it from another post on eevblog
https://www.eevblog.com/forum/projects/diy-metcal-13-56-mhz-rf-supply/msg438921/#msg438921
« Last Edit: July 26, 2017, 01:40:57 pm by Free_WiFi »
Offline macboy
« Reply #4 on: July 26, 2017, 02:48:14 pm »
Seems to me that your tip cartridge is defective. Try a different one and see if that helps. In contrast to typical soldering stations, the heating power of these is determined only by the tip, not by the base station, which just acts as a big RF power amp.
The following users thanked this post: Free_WiFi
Offline MosherIV
« Reply #5 on: July 26, 2017, 04:23:28 pm »
:-[ I was wrong. Metcal do not do inductor cartridges for the MX500/5000 serie handles.
They are only available for the older SP200 or the lower end PS900.
Try want macboy said.
Offline Free_WiFi
« Reply #6 on: August 03, 2017, 11:48:30 am »
Problem is solved !!! 8)
Basically my STTC-144 is defective .
I tried to plug my brand new STTC 536 and the problem of the overheat on my hadler is gone :)
Offline Free_WiFi
Re: Metcal MX500P [SOLVED]
« Reply #7 on: August 03, 2017, 12:03:18 pm »
Defective tip :
Offline macboy
« Reply #8 on: August 03, 2017, 02:02:58 pm »
Glad to hear it.
Note the STTC-536 is a low-temperature tip (nominally 500 degrees F, or 260 C). This is great for leaded solder with rosin based flux.
Offline Free_WiFi
« Reply #9 on: August 03, 2017, 03:02:18 pm »
Glad to hear it.
Yes i know , i already got 1mm * 500g* of Cynel 60/40 soldering wire :)
P.S
STTC-536 According to the metcal catalog (the number 5 stays for 302 C°)
