Author Topic: Rigol DS1052E On-Off Switch  (Read 587 times)
Offline firewalkerTopic starter
  • Country: gr
« on: August 07, 2023, 11:34:43 am »
I have a Rigol DS1052E with a broken On-Off Switch. Does anyone now if there is a replacement part? Can anyone identify the maker?
Alexander
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Rigol DS1052E On-Off Switch
« Reply #1 on: August 07, 2023, 11:55:10 am »
It looks like you have removed it. If it's truly broken as you say, i.e. going in the trash, I'd try to take it apart and check the inside. If you can pry the switch case apart you may be able to repair it. It should come apart by prying metal tabs, and go back together at least one time.
  • Country: gr
« Reply #2 on: August 07, 2023, 11:59:43 am »
I took it apart but the plunger broke internally and completely deformed (the students kept pressing with force) beyond repair the small metal blades.
Alexander.
  • Country: gr
« Reply #3 on: August 08, 2023, 07:59:40 am »
Its seems that with minimal filling a rocker switch, fits nicely.
Alexander.
Offline Haenk
« Reply #4 on: August 08, 2023, 09:12:15 am »
Hint: Google for "TV-5 switch". Plenty offerings...
Like https://www.ebay.de/itm/272280971139
  • Country: gr
« Reply #5 on: August 08, 2023, 09:23:54 am »
I couldn;t find none of those in my local supplier. And I couldn't locate it to TME or Digikey to add it to a pending order I had. I had to repair it this week.
BTW I believe the maker is BJ.
Alexander.
