Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Metcal tip luke-warm instead of hot
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Metcal tip luke-warm instead of hot (Read 718 times)
benj38
Regular Contributor
Country:
on:
April 06, 2023, 02:51:28 pm »
Hi guys,
I have a Metcal wide (22mm) flat blade tip that is not heating up correctly. it only gets up to a relatively low temperature, just below the solder melting point. The MX-5200 workstation power bar-graph always reads about 1-2 bars of power with this tip (instead of the regular ramp-up of substantial power draw on startup, settling after about 5-10 seconds to 1-2 bars).
Other tips I have work fine, so it is not the station or the handle.
Is this a normal failure mode?
Is there anything one can do to revive the tip (it is quite expensive
Thanks in advance,
Logged
mikeselectricstuff
Super Contributor
Country:
Re: Metcal tip luke-warm instead of hot
Reply #1 on:
April 06, 2023, 02:58:59 pm »
Something I've seen a few times is blobs of solder stuck in the coax plug at the end of tip causing shorts.
If not, it's probably shorted turns in the heater - sometimes temporarily recoverable with a sharp tap on the side.
It used to be the case that Metcal would replace any tip whose heater failed while the tip plating was still good - looks like this may still be the case - warranty is stated as "heater: lifetime of plating"
https://www.metcal.com/wp-content/uploads/2021/02/Metcal-Warranty-Chart-062021.pdf
Logged
Youtube channel
:Taking wierd stuff apart. Very apart.
Mike's Electric Stuff
: High voltage, vintage electronics etc.
Day Job
: Mostly LEDs
benj38
Regular Contributor
Country:
Reply #2 on:
April 08, 2023, 08:24:59 am »
@mikeselectricstuff, thanks for the tips!
Unfortunately, a sharp tap did not work, but it is good to know. The plug is also nice and clean, so I think it is a hopeless.
I will look into the warranty option.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
