Author Topic: metex 1280  (Read 2280 times)
Offline R_G_B_Topic starter
metex 1280
« on: August 06, 2014, 09:08:58 am »
I have an a problem with this meter it takes around 20 minutes to measure a 1 Meg resistor. The meter does this by first displaying the highest value its capable of reading and counting backwards ( converging to the value of the resistor being measured before counting back to its maximum residence it can measure. Can anyone please explain.
R_G_B
Re: metex 1280
« Reply #1 on: August 06, 2014, 01:17:38 pm »
intermittent connection problem
R_G_B
Offline retiredcaps
Re: metex 1280
« Reply #2 on: August 24, 2014, 10:04:27 pm »
Did you get this fixed? Was the above the problem?
Re: metex 1280
« Reply #3 on: August 27, 2014, 07:18:21 am »
Yes it was the 4mm sockets not allowing the 4mm plugs to fit snuggly. By the way the scope function on this thing is pants!
R_G_B
