Author Topic: Tektronix TDS520A A11 processor board Capacitors  (Read 1115 times)
Offline videoradar
« on: August 14, 2018, 08:42:57 am »
Hi All,
I just obtained a Tek TDS520A.
The A11 processor board is missing all the electrolytic caps and I can not find the values anywhere.
Most of them are fed from the same rail but there are a few that are not.
Any help would be much appreciated.
Online coromonadalix
Re: Tektronix TDS520A A11 processor board Capacitors
« Reply #1 on: August 15, 2018, 12:36:13 am »
Seen on another forum :
Tek used five type of voltage +5 -5 +15 -15 and 24v
Tried in vain to find the schematics ...  maybe finding some pictures around the web would help a little ?
Any tek 520 fanboys here ?
Online Chris56000
« Reply #2 on: August 15, 2018, 09:37:44 am »
Hi!
Download the free TDS520B Component Level Package from k04BB or the w140 Tek Wiki – I believe there are design differences between the TDS520A & TDS520B but it should give you a guide – there are schematics & parts lists in it, failing that I THINK you can get a "CLIP" (Component Level Information Package) from Artek Manuals for the 520/520A versions!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline andy2000
« Reply #3 on: August 15, 2018, 02:28:26 pm »
Schematics for the TDS544A are available here.  The processor board should be close enough to help.
http://hakanh.com/dl/kits.htm
Offline videoradar
« Reply #4 on: August 15, 2018, 04:17:10 pm »
Thanks guys.
The TDS544A schematics are very similar. I shall order the caps and fit them then power up and pray.
Peter.
« Reply #5 on: August 15, 2018, 08:35:47 pm »
bookmarked this one  thks
