Hiho,
have a Gossen Metrawatt Metrahit 24s here with a kinda strange problem. History of this meter is unclear, looks as it was heavily used.
If I power the meter up, it is set to AC and automatic - which is the first position of the rotary switch. It measures AC voltage quite OK - at least it somewhat agrees with my Sanwa and other meters I have. I don't have a reference for AC, so well, it seems fine, no idea.
So, first basic function works and I can also select auto or manual range - both work.
Turning the rotary switch does - nothing.
The meter stays in AC settings, although rotating changes the floating voltage on the leads a bit before settling around somewhat 3mV on any the positions of the rotary switch.
The meter has no obvious damages, we cleaned the board and poked around a bit - no shorted stuff found.
Anyone any idea where to look?
