Hello everyone!
Friend of mine described that while he was sleeping suddenly he heard a loud "zooooom" followed by a big "puff" and woke up. When he turned the lights on he saw a lot of smoke coming from his PC (Which he turned off before sleeping, but was still connected to the outlet and PSU switch on).
He asked if I could take a look at his PSU and see what happened.
Upon opening up there was a lot of electrolite liquid and the bulk cap had poped off... Also the diode and the mosfets of the PFC part are all shorted (remove from the pcb to test)
That was all I could find and test upon inspection...
I would like to know if you guys could help me regarding two topics.
1 - The diode is a STTH806D and the FETs are STF13NM60ND. I've searched for them on the area but could not find them... From your guys experience do you think I could replace them for: FQPF10N60C (Little lower Amp + Higer RDs(on)) and for the Diode I have two options which are RURP1560 (0.4 higher Vforw and 18ns Higher reverse time) and the MUR 860.
2 - What could possible be damaged fromt his failure? The secondary side could?
Thanks in advance!
