Author Topic: Metrawatt Metrawin 14s not working  (Read 877 times)
Offline duzycinekTopic starter
« on: November 17, 2022, 08:49:21 am »
Hello, anyone faced issue like this? All digits and symbols on LCD are activated at start, but nothing else happens. Any ideas?  Looking forward to hearing from you!
Offline shakalnokturn
Re: Metrawatt Metrawin 14s not working
« Reply #1 on: November 17, 2022, 10:46:04 pm »
G-M-C meters like most DMM's will enable all LCD segments on power-up as part of the self/user test.
I'd start with the usual checks:
On board power supply voltages.
Function selector switch contacts to MCU in case it is receiving invalid function information.
MCU oscillator.
MCU reset.
I²C bus integrity.
The following users thanked this post: duzycinek
« Reply #2 on: November 18, 2022, 06:02:54 am »
Thank you, I will check.
« Reply #3 on: December 11, 2022, 10:35:53 am »
Hello, the problem were buttons. Multiple were pressed at once. Without buttons is working perfectly. From side I can see that they are very close to press point. Should I make it shorter and put new conductive rubbers? Looking forward to hearing from you!
« Last Edit: December 11, 2022, 10:39:10 am by duzycinek »
« Reply #4 on: January 02, 2023, 11:52:12 am »
After shortening rubber poles and replacing conductive rubbers multimeter is working again!
The following users thanked this post: TizianoHV
