Author Topic: Metrix AX 323  (Read 1388 times)
Offline gianluigiTopic starter
Metrix AX 323
« on: June 04, 2021, 05:19:34 am »
I have power supply Metrix AX 323 with
2 output 0-30V 2.5A and one 4.5-5.5 5A
Has anyone schematic or service manual?
Thank you
Offline shakalnokturn
Re: Metrix AX 323
« Reply #1 on: June 04, 2021, 06:55:00 am »
Attached schematic for the older version of the AX322  with switches rather than potentiometers for the current limiting, I expect it to have a lot in common with the AX323.
Hope it helps...
Re: Metrix AX 323
« Reply #2 on: June 04, 2021, 07:28:47 am »
Thank you,
another diferrence is that AX 323 has LM324n on each section of output
