Hi, I have a Metrix GX 240 Signal Generetor that I picked up recently.
I just plugged it in this morning, and found out the although all the Signal Forms and other features are
functional, the output voltage, which should be 20VDC at maximum, is only a few millivolts.
Both of the 50R output terminals are connected on the board via a SDM resistor (impossible to read what’s on it; probably mounted upside down), and it’s actually a dead short.
Does anyone have a schematic for this? I can’t find it anywhere...
Thanks...
