Yes, to me it further confirms the PCB is contaminated.
The readings won't be off in most cases, I'd expect some error for high value resistance measurements.
Opening the case isn't hard once you know, easy to butcher when you don't.
The clip-locks at the ends need pushing inwards while slightly levering the 2 halves of the case appart.
It's hard to know how much leverage to apply, the water-proofing washer does offer some resistance adding doubt to whether you've actually released the locking clips.
