Replace those tantalums with 100V electrolytics, and look for every resistor over 47k on the board, especially those in a series chain, and either measure to see if the value is correct in circuit ( they will be lower than the printed value, short is not good, higher and it is open, unsolder then check again) or just replace them. Those are the startup circuit, especially on the top left where there are chains of resistors between the big blue electrolytic and the blue tantalum capacitor.
