Author Topic: Michrochip Brand Unknown Smd Component  (Read 3023 times)
Offline 2XTopic starter
  • Country: gr
« on: February 26, 2024, 09:06:11 pm »
Hello,
I have an smd component with the marking "CS0938" from Microchip company and I can't find any datasheet of it. You know if I have to remove some letters from the marking code in order to search for the datasheet? This PCB is from a trackball from a scan machine.
« Last Edit: April 19, 2024, 10:34:38 pm by 2X »
Offline DavidAlfa
Re: Michrochip Brand Unknown Smd Component
« Reply #1 on: February 26, 2024, 09:12:14 pm »
99% it's a voltage regulator given the large capacitors connected to it.
Probably a 5V->3.3V LDO.
« Last Edit: February 26, 2024, 09:23:27 pm by DavidAlfa »
The following users thanked this post: 2X
Offline fzabkar
« Reply #2 on: February 26, 2024, 09:20:26 pm »
I expect that "GAD" is the marking code. "0938" appears to be the YYWW date code. In fact there is a similar date code on the EEPROM (949).
"CS" appears to be the part ID. It's the 3.3V version of MCP1700.
MCP1700T-3302E/MB, Microchip, Low Quiescent Current LDO, 3.3V, 250mA, marking CS, SOT89:
https://ww1.microchip.com/downloads/en/DeviceDoc/MCP1700-Low-Quiescent-Current-LDO-20001826E.pdf
« Last Edit: February 26, 2024, 09:39:07 pm by fzabkar »
  • Country: gr
« Reply #3 on: February 26, 2024, 09:54:17 pm »
https://gr.mouser.com/ProductDetail/Microchip-Technology/MCP1700T-3302E-MB?qs=WWgnj3qycfnlJJhwyn%2Fifw%3D%3D
The following users thanked this post: fzabkar
