The inductor is about 12ohm, any suggestion for the next step?
I guess it's wound with very thin wire if shorting leads of multimeter shows resistance close to zero. It any case 12 ohm is enough to route away almost all of DC current from that resistor. I assume C21 is faulty then. If you don't have replacement, you can exchange C20 and C21 and see what happens. If it starts working, order new capacitors.
Sorry for long holiday in my country, now I am back.
Yes, it is wound with a very thin wire. So I temporary soldering back the inductor. I replace both C20 and C21 because the old caps have liquid damage on each side
I replace the burning resistor with new 1.5k. Every things good Then i turn on the power for testing but there is no sign of voltage.
after measuring with the multimeter I inspect the resistor(R5) skin is crack. it is 5 band resistor. I send it to an electronic shop they send me a back 38ohm resistor they said it can replace.
Then after i replace with 38ohm resistor and power on, boom! the new R5 is exploding.
so what next?
