I just opened up the pedal, there is a control board under the middle pedal. It has a few microchips on it, completely caked in dust. I'll try to just clean things up first and see if that helps. Perhaps there is a short or the dust is causing signal problems as it was completely coated in a fine grey powered dust. I'll also try to unstick that "1" button switch in case that is preventing the other buttons from creating a signal. Still, it seems like a complex design for a foot pedal. I'd be interested in just learning how it works and why they decided to do it this way. And how is the signal sent along the 4 lines? Are they using a 16-to-4 line encoder? But how would they get power to the foot control? If one line is to send power, you would have 3 return lines and a priority encoder would only be able to handle 8 buttons encoding to 3 lines (actually 7 buttons because by default when no buttons pressed that might correspond to 000, then each of the 7 buttons when pressed would give 001, 010, 011, 100, 101, 110, 111).
