Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Miele Induction cooktop repair KM5731 error 32
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Miele Induction cooktop repair KM5731 error 32 (Read 3880 times)
adam1213
Regular Contributor
Country:
on:
July 17, 2021, 07:49:41 am »
The cooktop would frequently turn off when turned on and give error 32. Once it had decided to play nice and was powered up it cooked as usual.
i found some repair info for it online and it worked a treat. Essentially there were some bad capacitors. Added own pictures
I probably should still replace the flat flex cable that looks a bit burned. Its working fine. As I don't have one / know the part for know I just swapped the cable with the cable on the other side of the board in order to get more life out of the parts.
for anyone attempting a similar repair a few tips: don't touch the white circles, the bus bars in where the power connects to the board need removing to remove the pcb.
I personally decided to go with this capacitor
https://au.rs-online.com/web/p/aluminium-capacitors/7621689/
https://www.stereo.net.au/forums/topic/107339-replacement-or-better-capacitor/
https://miele-induction-cooktop-error-codes.peatix.com/
https://www.klusidee.nl/Forum/topic/storing-fe32-miele-inductie-kookplaat-km5732.97663/
https://www.klusidee.nl/Forum/topic/storing-fe32-miele-inductie-kookplaat-km5732.97663/page-2
The cooktop is powered by at ATMEGA32-16AU which features 4 PWM channels, 8 channel ADC (for temperature sensors, reading feedback to determine if there is a pan etc, inductive button interface)
Last Edit: July 17, 2021, 09:24:34 am by adam1213
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
