It's a 273 model. Btw. not to confuse with the "i" models, those are newer inverter machines.
I can't figure out what the resistors actually do there.
The two (on the working board) 33 ohms resistors measures ~1 ohm in circiut, but i'm probably measuring series/parallel with other components.
I'm impressed, that a small Danish welder find it's way to NZ. But they used to be strong and reliable machines.
EDIT: Holy, that schematic is old - From the day, where they documented their machines.. My newer Sigma2 400 aren't documented at all. At least not for public. Sad, but the machine is still awesome.
