So, just to complete this thread. By the way, I was able to compare readings between
the failed board and a known good PC-1 board. That was a big help.
* 350P Aluminum Welder had HELP 6 code and push pull gun motor did not turn
* Replaced Q23 and Q24 on board PC-1
* HELP 6 code cleared but gun motor still did not run
* Replaced D5, D6, and R264 on board PC-1
* Welder now works as normal
Q23 and Q24 are FDD3682 Mosfets
D5 and D6 are P6SMB15A-E3/52 Diodes
R264 is a LRC-LR2512LF-01-R200-F Resistor
