Acid
Depends on the rust badness level the worse it is the stronger the acid should be used
consult chemistry sites, just brief;
HCl strong
Citric Acid mild
Acetic Acid weak
On very strong eg. HCl ~33% it absolutely must be diluted with water by way of some water in a holder added/dripped little by little with some HCl
So let's we have 29%-30% HCl for ugly rust, the way is to put it in a small bottle.
As one hand hold cotton bud dripped, damped from that, the other hold a clothe damped with IPA mixed with some water, so as starting to clean up do it rather precisely only the rusted part wiping/rubbing it with the acid in a hand, then wait seconds, if it wets the non-rusted part, immediately wipe it with the other (prepared IPA) then at last thoroughly wipe, clean all the Acid-reacted part altogether with the IPA
On better rusted part just do first part, no need to hury wiping it with IPA then at last thoroughly wipe, clean all the Acid-reacted part altogether with the IPA
