i picked this up off ebay recently and have been poking around with, powered it and had a scope around a little to just verify that it works but it's puzzling me because it both appears to work but also not.
The meter is old, you can see from the picture it had 'new' batteries in 32 years ago so probably dates from the 70s.
Inside there are two sections, one is clearly the GM / analog meter driver board which is connected to a logic / display board with a simple two wire interface (10v falling edge pulse). The digital board basically gives you a reading over a specified time selected by the adjustment knob.
Powering it on the meter will begin to move as i would expect for background radiation, on my scope i can see randomly spaced pulses at reasonable intervals.
BUT there is no different response when i bring a radioactive source near it, i have some uranium glazed Fiestaware that will give me 4000 counts/min on my other GM counters.
If i disconnect the probe the pulses go away and there is a good 415v coming from the driver which is all as i would expect.
Unfortunately the probe is sealed and the sticker worn off so i have no idea of the internal GM tube but it is massive. The meter is in uR so should be pretty sensitive.
I dont know much about how GM tubes fail, but i would have thought they just go deaf and dont produce any output? If anyone can clarify?
Seems odd that it seems to be showing activity, but not responding to something radioactive.
Any thoughts??
