Author Topic: Repair suggestions for cracked Fluke 87V screen protector  (Read 5811 times)
Offline nikkodericTopic starter
  • Country: ph
  • We're all human, we're just like you man.
« on: April 14, 2016, 04:35:02 pm »
Hi community!
I'm a Fluke fan  ;) and I'm very glad to have a Fluke 87V multimeter as an ECE undergraduate student, so when I realized that I cracked the screen protector of my multimeter after I cleaned it I got very  :(    :-- . I just want to ask if there's anything that I can do to fix this (or make it less visible) without buying an entire front case replacement. I'm from Philippines so buying a replacement would be very hard and expensive (almost impossible) for me.
I thought Fluke multimeters are almost indestructible.  ::)
Thanks for your help. =)
Offline Jonny
Re: Repair suggestions for cracked Fluke 87V screen protector
« Reply #1 on: April 16, 2016, 09:53:25 am »
What about an automotive glass windshield repair kit? It's OCA UV cured resin you force into the crack. I'd guess about $15 at an auto parts shop.
Jonny
Offline stj
« Reply #2 on: April 17, 2016, 04:42:52 am »
if the print is on the case, not backprinted on the clear section, i would be tempted to ask a glass shop to make a 3mm hardened glass replacement wih rounded corners and bevelled edges
the piece is so small that they could use a bit of scrap from the bin - so you would only be paying for the cutting and grinding.
the car windshield stuff wont work, they have to put a small vac chamber over the glass and suck the air out to use that resin.
Online Shock
« Reply #3 on: April 17, 2016, 06:16:04 pm »
Be contacting the repair agents close to you to see if it's covered by warranty.
  • Country: ph
« Reply #4 on: April 19, 2016, 06:04:29 pm »
Thanks for suggestions! I'll give the windshield repair a try since we actually have a vacuum chamber. Having someone to recreate the screen protector is actually a very good idea. I'll definitely do it if the windshield repair yield unsatisfactory result or we cant, after all. The multi meter is actually a second hand one and sold to me without manual and warranty "documents" so I don't think it can still be repaired under warranty.
Thanks again! =D
« Reply #5 on: April 20, 2016, 07:12:58 pm »
Have a look at the small kits that are used for repair "on the go" as they include a small suction cup that is fitted to the syringe applicator and which is pulled back to make a pressure pulse of liquid that is forced into the clean crack to fill it before you do the UV cure. On glass it is almost invisible after repair.
Offline JFJ
« Reply #6 on: April 20, 2016, 09:41:54 pm »
There was a used Fluke 87V top case on eBay, a few weeks ago, with a crack in the same place. If the cracks are due to an inherent weakness in the case design, then it may be worth reporting it to Fluke.
