Author Topic: Missing display segments on power supply  (Read 1180 times)
Offline Brad808Topic starter
« on: November 23, 2022, 04:53:10 pm »
I have a power supply (power ten 3300 series) that has some weirdness happening with the voltage and current display segments. I have a couple of identical power supplies so I've been able to narrow down my issue a bit by swapping some parts. Unfortunately I can't find a copy of the schematic. I'm sure I'll be able to track down the issue by swapping parts, but if any of you here have any idea of what I should be looking for I'm more than happy to take advice.
The current display was showing random digits and missing segments like this;
The voltage display was showing the correct voltage but for some reason now it is 13 or 14v above what it should be and the pot isn't able to adjust it out.
Here is a description of the board operation:
Here is some photos of the board:
https://imgur.com/a/qJgmUAG
Couple of things I've done:
- swapped the whole display board to another unit and the problem is definitely on the display board, not the main board
- retouched all solder joints on the board (minus the sockets underneath the LCD which I'll do tonight)
- swapped the two AD converters in u3 and u4 with ones from a working board
- verified the +/- 5v regulators are working.
That's about as far as I've gotten. I'll keep working away at swapping parts and testing individual components, but any help is appreciated.
Online coromonadalix
Re: Missing display segments on power supply
« Reply #1 on: November 23, 2022, 06:18:05 pm »
you could have some bad contacts with the pin vs the glass substrate  ?  mechanical failure
Online wraper
  • Country: lv
« Reply #2 on: November 23, 2022, 06:27:31 pm »
Looks like faulty display. Sometimes adhesive delaminates and metal terminals no longer have continuity with the contacts on glass. Looks like a fairly common off the shelf LCD like this https://www.aliexpress.com/item/32920933993.html
« Last Edit: November 23, 2022, 06:32:19 pm by wraper »
Offline floobydust
« Reply #3 on: November 23, 2022, 06:36:37 pm »
Yes it sounds like you've tried everything leaving a failed LCD display. It might have a hairline crack open-circuiting the segment traces on the glass. You can poke it and apply a little pressure here and there to see if anything changes. An air bubble usually makes for an odd outline on the segments. With old 80-90's LCD displays I find some kind of tin whiskers form inside at the electrodes.
The part number is written on the LCD backside, so you'd have to pull it.
« Reply #4 on: November 24, 2022, 01:21:24 am »
So tonight I was able to fix the voltage issue (I didn't realize the how the LCD jumpers were set so easy correction there).
I was able to confirm the display itself is bad by swapping them around (bit of a pain to be honest).
This is the model number of the display. I really don't know anything about them but can anyone confirm a good replacement for me? would the one posted earlier from aliexpress work? thanks
Online wraper
  • Country: lv
« Reply #5 on: November 24, 2022, 07:43:20 am »
You need to check dimensions and exact pinout, and compare with aliexpress listings or datasheets. Easy to do by touching terminals with unearthed soldering iron, some phone charger or anything else that has some capacitive leakage from the mains voltage. I'm pretty sure such displays are still sold by western distributors like Mouser too. Suggest replacing both displays, for matching appearance and long term reliability.
« Last Edit: November 24, 2022, 07:47:51 am by wraper »
Online wraper
  • Country: lv
Offline Swake
« Reply #7 on: November 24, 2022, 05:13:38 pm »
3 1/2 digit LCD. Typically driven by an Intersil ICL7106 A/D chip. If that is the chip you have it is a very common display.
Edit: didn't notice the pic of the board, yes that is the chip you have. the second chip is likely a clone or already a repair.
« Last Edit: November 24, 2022, 05:18:03 pm by Swake »
When it fits stop using the hammer
Online wraper
  • Country: lv
« Reply #8 on: November 24, 2022, 05:36:56 pm »
They are both clones. NTE2051 from NTE and TC7106 from TelCom semiconductor (acquired by Microchip). Both look quite old.
