Author Topic: GLI PRO XA2200 AMPLIFIER  (Read 325 times)
Offline COLLANGETopic starter
  • Country: jm
« on: February 26, 2023, 07:28:10 am »
Trying to fix a Gli pro xa2200 amplifier which powers on but has no output audio change a few bad resistors and transistors but not getting a 12v at the dpdt relay needed to switch it on. A voltage regulator has the right input 14 to 3ov an 12v output rated value. Can't find a schematic or service manual online and I can't figure out why am not getting the 12v needed to switch the relay on. Your kind suggested fix are welcome. Thank you
« Last Edit: March 04, 2023, 07:56:28 am by COLLANGE »
Online coromonadalix
Re: GLI PRO XA2200 AMPLIFIER
« Reply #1 on: February 26, 2023, 02:47:57 pm »
Welcome here
Please dont write in capital letter,  it can be considered as yelling in some forums or here
Not sure, but they do ressemble some Bryston  amplifiers ??   never heard of this brand, and could be a copy of another brand
check pcb markings / names etc ...
« Last Edit: February 26, 2023, 02:51:33 pm by coromonadalix »
