Author Topic: Mitsubishi E200 HMI  (Read 226 times)
Offline gurarTopic starter
Mitsubishi E200 HMI
« on: October 15, 2024, 03:17:05 pm »
Hello,
I have several Mitsubishi E200 HMI with similar problems.  They power up OK and run the self-test diagnostics OK.  However, they immediately show messages "Formatting Flash" and "Erasing Memory" before going to the Edit/Transfer/Setup menu.  At that point, I can navigate the menus and then load and verify my project via SW-MTA-WIN and the HMI functions normally.  If I quickly cycle power, it starts up normally.  If I wait several seconds before powering up, I get the Formatting and Erasing messages again.  I have replaced the surface-mount flash memory chips with no change and loaded BIOS 4.03 with Sysload.  Any ideas why my project keeps getting erased?  Thank you.
Offline coromonadalix
Re: Mitsubishi E200 HMI
« Reply #1 on: October 15, 2024, 03:31:58 pm »
some talk here
https://www.plctalk.net/threads/beijer-mitsubishi-e200-flash-error.54638/
i would have said  program corruption,  memory corruption ...   maybe the bios is going nuts,  any updates with more recent ?
https://www.reddit.com/r/PLC/comments/1d7hurr/hello_i_have_beijer_mitsubishi_e200_program/
https://forums.mrplc.com/index.php?/topic/23676-e200-hmi/
some help on plc forums  ???  PLCS.net ....
« Last Edit: October 15, 2024, 03:34:10 pm by coromonadalix »
« Reply #2 on: October 15, 2024, 03:39:11 pm »
Thanks.  That first link was also me, 14 years ago.  No luck back then, and I returned the HMI I had bought on ebay.  I have a little more experience now, but this is clearly a board issue.  I had assumed the flash memory chip was faulty (thus requiring to be reformatted), so I got some new chips and had them installed.  High hopes, but no luck again.  Dunno if the RAM chip or main processor is causing this trouble, or maybe something else on the board.
