Hi all,
i bought a month ago a tek 577 with a few fixtures, since then i’ve tested it a few times and it was working but was a little out of spec, so i’ve dediced to do a little calibration and found out that 2 trimpots weren’t working (the R1245 and R528 ).
Ordered some linear ones on digikey (the manufacturer is piher) and replaced the R1245 one. In the mA range everything is working fine but when i switch the vertical/div knob from mA to lower ranges the collector protection light turns on (and the beam on the crt gets greatly out of range), i don’t believe it was the R1245 that i’ve replaced, maybe the preamp in the 177 or the amp inside the 577? I don’t have much time testing all the components, as anyone had a similar experience?
In addition, i see only now, that the 200 volt line on the power board is at around 218v…
Thanks in advance
