Hi!
I just bought a used tube guitar amplifier, a Mesa Boogie DC-5. On the PCB in the area of one of the preamp tube sockets someone has really gone to town with the soldering iron and damaged the board. There are several places where I can see exposed fiberglass. Does this mean that there is increased risk of the board going conductive in the long run, due to moisture ingress? Also, what happens to the fiberglass if any solder flux gets in there? Would that also tend to increase the conductivity?
If so, what are the recommended ways to seal up the areas with exposed fiberglass, for an amateur such as me? Can I use a bit of superglue, or should I get something tailormade for such applications? If so, what?
Here is a photo of the area. A conductive board would be quite bad in this "high impedance area", where the tube grids should have a round 1MOhm to ground and there are voltage differences around 300VDC on the tube socket pins.
As a bonus, they melted a lot of the wire insulation as can be seen in the photo, in addition to creating an enormous solder ball on the back of the PCB, which caused one of the tube socket pins to be shorted to ground....
Best regards,
Torquil Sørensen, Norway
