Author Topic: Monitor Problem (No Signal)  (Read 2295 times)
Offline bauhausTopic starter
« on: September 15, 2014, 05:47:51 pm »
Hi!
A friend of mine gave me an old monitor (hitachi cml158xw) which has a problem.
When I connect it to a desktop, the monitor powers on (power light turns green) but I get only a blank display. When I disconnect the vga cable, I can see the known messages (no signal, etc) and the light turns yellow. If I reconnect the cable, the light turns green again.
As I presume, the monitor receives signals from the vga card (I've also checked the continuity of its pins, and it is ok).
Also, because I can see the info messages (e.g. no signal) I think that the fluorescent lamp is ok..
I've also checked (visually) the monitor's board and I didn't see any burnt caps/diodes/resistors/etc.
Do you have any idea what to check next? What would be the fault?
Any help would be very much appreciated!!
Offline tautech
Re: Monitor Problem (No Signal)
« Reply #1 on: September 15, 2014, 11:28:14 pm »
Welcome to the forum.
Confirm backlight is working when connected by shining a flashlight at the screen and looking for info illuminated.
Maybe this screen won't display you current PC settings.
Are the PC video settings set to default monitor to start with?
Avid Rabid Hobbyist
« Reply #2 on: September 16, 2014, 08:14:03 am »
Thank you for your reply!
I'll check the backlight this afternoon. I also forgot to mention that I cannot even see the osd menu, although I can see the "no signal", "connect the cable", etc messages.
If there is a problem with the backlight, these messages couldn't be displayed, right? or not?
I'm confused.
I've tested the monitor even in 1024x768 pixels display resolution. Nothing.
Offline tautech
« Reply #3 on: September 16, 2014, 08:38:46 am »
You are correct, you would not see the messages.
Are you trying to use the monitor as a second monitor?
Try connecting it alone and see if the video card identifies it on boot up.
Avid Rabid Hobbyist
Offline Psi
« Reply #4 on: September 16, 2014, 08:39:52 am »
Does the monitor have any other inputs you can try? VGA / DVI / DisplayPort / Composite etc.
« Reply #5 on: September 16, 2014, 03:58:55 pm »
No, I try it as a primary monitor (alone). It only has the standard d-sub (vga) plug.
