In this circuit, which is a PSU board for an audio amplifier, Q3 IRF740 (The one highlighted) keeps blowing up (short between the three legs)
Sometimes this short happens right away after the relay click, and sometimes it takes a few minutes. The first time it blew it took like 2 hours of operation before it blew up.
The four mosefts and the TOP243 gets hot in standby, about 50-70 C. Which is as reported by others normal for this board.
I checked everything around this mosfet and the individual components seems fine.
What can cause such failure?
What can cause such failure?hi,
i suspect something in the 'command' loop for Q3, like C57, C29, C54 maybe some diode like D23 (is she ok?if it's opened, you may have some spurious spikes there killing G-S junction), maybe bad diac (but i saw this rarely)
(you can just replace those caps tocheck)
top243 seems independent supply, so nothing connects this to your problem
voltage on C59 and C60?
It's difficult to see in the photos, but aren't the mod wires for the gate and drain touching the trace connected to the source? Is there more than the soldermask providing insulation?
Another option, the replacement IRF740s could be fakes?
The solder mask seems fine, I will added an extra layer of the UV curable solder mask though, won't hurt.
The original IRF740 did blow up though, there is a problem somewhere.
The replacement may be fakes, yes. But even if they were fakes, would it blow up without any load connected?
Don't connect it directly to the mains! Put a 50-100W bulb in series!
If the transistor is permanently switched on, it will bright like a normal bulb, but keep it from blowing.
Normally it will be barely lit, red-orange.
Check the reverse voltage on zener diode D23 (ensure it doesn't go over 15V), also the snubber C29/R36, it filters the huge switching spikes, the mosfet will die quickly if exposed to such voltages.
The reason why I mention it is I shorted out an audio amp once because there was a single wire strand touching a nearby trace. I couldn't see any holes in the solder mask but it was still shorted, that was only at a few volts as well. This is quite high voltage so I think you'd be better striping the wire insulation off right where it goes into the through hole.The original IRF740 did blow up though, there is a problem somewhere.
It's unlikely but possible. Some of the fakes switch slower than the genuine parts so they are still conducting when they should be off etc. Just something to keep in mind, there most likely is another fault as you mention.
What are the repairs you have already done on the board?
The replacement may be fakes, yes. But even if they were fakes, would it blow up without any load connected?Totally wrong assumption. Original MOSFET may easily fail independent from other parts. And if you use crappy counterfeit as replacements you will have further failures.Quotethere is a problem somewhere.As if the MOSFET as one of the most stressed components must not fail first, and there must be an issue somewhere.
Something new happened that I don't know if it relates to this issue. C70 bulged. It's a new Nichicon GU series cap, It just won't bulge on it's own. And it's supposed to be on Q1 and Q2!
Also something I don't understand, D22, D23, D24 and D25, the zener diodes at the gate of the mosfets, the read voltage drop in both directions while in circuit, but only in one direction out of circuit. The 4 diodes can't all have gone bad! And I can't understand why they are reading in the opposite direction in circuit.
This is a tough one, it doesn't look that complicated, but I still can't see a clear reason for the MOSFET to blow or C70 to bulge. Is R23 the correct value? Looks like it might have got hot at some point?
Just some observations...
R36 (47R) is part of the snubber network and looks like it has a dry joint. Reflow it.
On the schematic, component designator C56 is duplicated. C28 (220pF) on the PCB is C56 (220pF) on the schematic. The other C56 is 3.3nF (greencap) capacitor. This isn't part of Q3 circuit, though.
Since Q3 MOSFET has failed numerous times, what is the likelihood that the primary HVDC winding (pins 5 and 6) has sustained some damage when Q3 drain-source channel short circuits? As a last resort, try swapping transformers T1 and T2 and see if the fault follows the transformer or stays with Q3 MOSFET. I suggest this idea because PSU1 and PSU2 are seemingly identical from what I can see in the schematic and are common to the startup circuit of Q6 etc. Maybe exercise some caution/discretion with this suggestion.
For 230V version (which is configured on the board), the upper (A-X) and lower (Y-B) parts are in series to mains voltage. Both sheets of the main PSU schematics are in parallel, so C59||C69 and C60||C70. If the upper part (with the Mosfet Q3) is shorted, the whole voltage is applied to Y-B, where the cap C70 is only rated to 200V. R2 and R23 are the bleeders/balancers (where during normal operation the balancing should be done by the current the switches are drawing). Performance of caps C59/C60/C69/C70 will also affect the balancing, but they are replaced. With one bulging, I doubt these are still in spec. Even short times of overvoltage will degrade the caps, maybe they resume from insulation defects with some time reforming them. Running it on 110V with changed configuration is more safe to the board during testing.
This a self resonating circuit, it starts with the pulse to Q3/Q4. If there is a short or break in the transformer, current flow may not stop before the FET is broken, it will happily convert to a self destructing circuit. If possible, disconnect everything from the transformer and try to inject small pulses and see the ringing with a scope. Compare both transformers.
This is a tough one, it doesn't look that complicated, but I still can't see a clear reason for the MOSFET to blow or C70 to bulge. Is R23 the correct value? Looks like it might have got hot at some point?Since this a self resonating circuit, and the mosfets are in pull push configuration. Should both mosfets be identical? Same manufacturer and properties.
Or is it acceptable that they have slightly different RDs-ON and different manufacturer since both have the same model number IRF740?
And if the mosfets are slightly different, will that cause failure.
Another question, When I'm testing the circuit, I have disconnected the sound amplifier boards which are the load to that output, will the lack of a load on such a circuit cause a failure?
i'm not really mosfet expert, but i think rdson is not very very important, mosfets could be different (in some limits of course), for me frequency specs could move the boat (commute time).
i doubt the transformer is damaged, you can swap and test, fortunately you can in this case.
btw, if you want real protection, put the bulb in series with mosfet drain (the one who blows), then you save everybody, mosfet included. calculate the 'biggest' bulb accepted and use one close to that wattage (regarding max current accepted by your mosfet). this was always my technique, putting the bulb on mains lets place to such thing like trace popcorning, transformer overcurrent and so on. of course it doesn't protect 100%, with shorted mosfet you have to disconnect quick the mains, you'll put some big dc current into the smps transformer, but keeps it under control better
so i think you missed something in that mosfet control loop or maybe we don't really understand how this ps is working
you may also change c32 ( i strongly advice you to CHANGE the caps, not measure them, until this is resolved).
why? look at the bulged cap example...with your lcr or multimeter powered from 9V you can measure 2-3 parameters, but never ever you will put that cap to 1KV voltage, so the (potentially damaged) isolation will never show up. usually your method is ok, but nor those non-baptized damaged pcb, the caps is better to be replaced, we will analyze what's happened after successful repair
I switched the mosfets around so that Q3 and Q1 are the identical and Q4 and Q2 are identical, to prevent further damage I followed dl6lr advice and hooked the board to 110V power source and it worked fine. Gave it 5 minutes and it kept working fine.
Switched the jumpers to 230V configuration, and started the system, the lamp in series started to glow after I heard something like a hiss or small sparks somewhere on the board, immediately disconnected the power and nothing seemed to blow. Tried again but still can't figure out where that sparky sound is coming from. Switched the jumpers back to 110v and thought of measuring some voltages, it worked for like 10 seconds and the the relay started clicking on and off rapidly. Now Q1 is blown.
of course q6 was good, without him the ps blows at first start or does not start at all
the whissle sound is the frequency going rogue and i think we should start to investigate if 'lower' branch is working (i mean Q2 and his friends, maybe the negative alternance isn't right causing the positive to die)
if you don't want to replace caps, at least start to exchange them between supplies, but C54 should be changed being unique.
the relay is powered by the other ps, he sould remain steady, except if D1 bridge is on excessive load (shorted on output), making top243 ps to fail.
i think you covered the basis like verify if D1 is ok and you have the correct DC voltage on C6 and C69-C70, a shorted diode in that bridge will make dust from our suppositions
you're right about mosfet control loop Q6+D6-D7 putting Q2-Q3 in conduction, but the control loop extends to those secondary windings 7-8 and 1-2 for example, those are shutting off the mosfets via C57...
for me, resistors and caps are easy to diagnose so the heavy task is to exchange T1 and T2 eliminating this (i don't think T1 or T2 are bad, those models are pretty sturdy, but who knows, attacking them with repetitive blows may damage 5-6 winding.
keep digging
This is somehow strange. The FETs to be identical should be Q3/Q2 and Q1/Q4, as those build a PP drive to the transformer each. I would just disable the second PSU completely to isolate the problem (or use it first to get some measurements on the working circuit).
So the unit worked for 5 minutes in 110V configuration with 110V supplied? With or withoud load?
Some thoughts, maybe wrong: TH1 is the inrush current limiter. The relay is driven from electronics supplied by the AUX PSU so if the voltage is low because the bulb starts to glow, the relay may switch off. Just bridge the relay for tests. When the MAIN PSU gets its DC input voltage, limited by TH1, C59,C60,C69,C70 will be charged, either in parallel (110V) or series (230V). With Q6 and R14 the two DIACs will be pre-charged, at about 60V the DIAC will drive the Gate of Q3 positive against the source, so Q3 will switch on and current from will flow thru the transformer. The source will "jump" to high voltage but the gate floats with it. The current induced into the second winding and as long as voltage on pin 7 of T1 rises, current flows thru C54 and keeps the gate high. When the core saturates, current thru Q3 increases but current/voltage at pin 7 will decrease, so gate will be pulled low thru R63/R66. Current thru Q3 stops and decreases, inducing voltage in opposite direction which will turn on Q2 thru C56.
Ratings of the FETs are 10A, the bulb should draw a current that is lower. So even one FET stuck should not blow it up. 200W on 230V will be roughly 1A with higher inrush. I would try a lower value like 60W to start with, but a IRF740 should not bother the current from the lamp. So there must be another error, like failing snubber or excessive startup drive.
Check R14, R15, R16, Q6, D14 and C54. With D15 and D16 removed, the PSU should not start up (but beware, any kind of spike to one of the gates will start it). Check D23 as a failing zener may exceed the Ugs (20V) of Q3. It should have 0.7V forward and 15V in reverse. In circuit you will not get the right values as R63-R66 are parallel to it.
